Wrecked cars needed
on
Wrecked cars needed
If anyone knows of a junkyard that has a wrecked crossfire will you please let me know their number or address. Need a few parts that I can't find in the marketplace on here. If you're reading this and have two spare headlight bulb clips then you just solved my problem but I'd still appreciate info on any wrecked cars. Thanks guys
Re: Wrecked cars needed
My good friend "Shibing" used these:
and some needle nose pliers to bend them into shape.
If you remove the entire head light and shake it, you might find the clip has fallen inside.
Amazon.com: Trussing Needle - 8-Inch: Kitchen Tools: Kitchen & Dining
maxcichon sells clips he makes, $8 each I believe. The OP should contact him.
Last edited by onehundred80; 07-01-2015 at 09:21 AM. Reason: maxcichon was Maxichon, I stand corrected.
on
Pretty sure all you do is take some bolts out from the top and bottom and then pull the bumper out a little so the light has room to slip through. A lot of people say you have to take the bumper off, but you don't.
on
One of the bottom ones you can reach inside the engine bay.. the other one.. pull the side marker out and you can access it. Also remove the facia bolt at the top by the radiator.. it give you more flex to push down on the bumper. I slipped a micro fiber towel in between to keep from any scrapes as it is a tight fit coming out.
It helps to also remove the 2 hollow adjustment thingeys on the bottom of the light assemblies.
When reinstalling, get the light in and start the adjustment thingeys back in the holes,
position the light ( after reconnecting the harness and installing the marker light ),
tighten up the top 2 light bolts, then
screw the adjusters up until they just contact the mounting flanges, then secure with the bottom 10mm bolts.
on
I'd say sell your car as it seems like a lemon.
on
I would but I'm scared I wouldn't get enough for it. 5k or 6k is probably all id get with all the crap that's wrong with it.
on
rayth
41
07-31-2019 04:02 PM
WindRestrictor
06-01-2015 02:31 PM
