Recent fix
Recent fix
Hey everybody. I just joined up here on the forums.
First off I want to thank thighed1 for his excellent knowledge and how to article on the 'mysterious no start' problem. I just started encountering it last month, and after replacing the starter with no luck, I decided to shop around for advice. And that's how I ended up here! With that 'how-to' and some easy to access resources, I was able to fix the issue next day! So, in closing, it's nice to finally find a community for this car, and reliable knowledge. See you all around!
Re: Recent fix
Haha. my original locale is not too far from sierra vista!
but i live in new orleans now!
and i have '04 an alabaster coupe
pics uploaded soon
I originally got the car for $7,500 too, from a family friend, so I think i got a decent deal! It only had 94K miles at the time.
pics uploaded soon
Re: Recent fix
So I managed to re-attach all of the exhaust that I had to take off to get to my starter. Upon starting my car, I noticed a very evident hissing sound coming from what seemed to be somewhere under my battery. The BAS/ESP light also came on, but went away very quickly. I'm guessing it might be a hole in some hose making the sound?
Re: Recent fix
So....
My crossfire won't start again. The relay control module solder points that i recently fixed and resoldered are fine. But my car will not crank, at all. I turn the key, it hums, and just sits there.
Replaced the starter, and still no help. I'm literally at a loss for ideas. Possibly the fuel pump or ignition?
I don't think it could be the battery because the radio, lights, windows, etc all come on....any ideas? help would be much appreciated.
Re: Recent fix
Originally Posted by jabk
So....
Re: Recent fix
Originally Posted by live2drive
Try turning your key the opposite way when sliding it into the ignition switch. It sounds stupid, i know, but I just got my car two days ago and noticed that occasionally it would only start when i flip the key around. Hopefully the fix is that simple; good luck.
did this help????
Re: Recent fix
Jump starting the battery yields no results, and the terminals are clean and not corroded.
Will try the key flip today, but I don't have much hope. If that is the case though, shall I just look for a whole new ignition?
on
Re: Recent fix
guys, just because you have lights and radio does not mean the battery is good..... it needs to be tested under load to find out if it is bad or not.... the lights and radio take very little power to work... cranking the engine to start takes a HEALTHY batter putting out at least 12V and enough amps.... there have been two (or three) recent posts of people that couldn't get the car to start and thought they had a good battery only to replace it and everything was fine..... get your battery tested....
Re: Recent fix
on
Re: Recent fix
11.8v is probably too low... I had an intermittant no start issue that my battery showed about 11.7 - 11.9v and wouldnt start.... I could hook up my charger and set to 12v 200 cranking amps and the car would fire right up....
Oddly my problem was only during cold weather and turned out to be a very slightly damaged flex plate that had to be replaced.... this also gave me P0335 Crankshaft Position Sensor errors...(the flex plate is what the CPS looks at to generate pulses)... yes it was a strange problem...
Re: Recent fix
Re: Recent fix
Battery has 12.5V sitting on it. still no start, but I suppose i will try getting a new battery. I'd hate to go buy a new battery to not have it fix the problem, but I'm really running out of options :/
Re: Recent fix
Originally Posted by Pterodactyl
OR... you might be missing teeth on your flywheel.
Looking back through the thread....
You had a no start issue..
You replaced the starter..still no start
You soldered the RCM and it started
Now it's back to no start.
Was the replacement starter a rebuilt or something that could have been marginal?
Did you ever investigate the "hissing sound"? Thinking that would be an exhaust
leak, and have to wonder if it hasn't created an issue?
One more thought... "terminals are clean"..is that just looking at them or have you
actually taken them loose and sanded the contact areas of the post and clamps to
insure a good connection?
