R.E.S.T & Car Alarm
Re: R.E.S.T & Car Alarm
CyberGreg; You have two alarms, remember the one on the dash in case someone trys to jack up your car to steel your tires or tow it away. Of course you have the regular alarm also. The alarm even has its own rechargeable battery pack so disconnecting your battery does not disable it.
Once the alarm is on, it is triggered if you: 1. open the doors, hood or hatch 2. try to remove the radio 3. jump the ignition 4. open the glove box
English_Bob,
If everything was working right and you set your tow away alarm, before you left the car, then someone could have set it off by leaning on your car.
English_Bob,
There was a shady character lurking about when I returned to the car (he wandered off and then watched from across the street). It is possible that he set the alarm off either accidentally or deliberately. Hopefully just an admirer that got too close.
I will be using REST again in January so I will see if the alarm is triggered again.
My alarm has gone off twice just sitting in the garage. I wasn't using the R.E.S.T. feature either time. It happened within a couple of minutes after I got out of the car and went into my house. This happened shortly after I got the car and hasn't happened since. There is nothing quite like the alarm wailing in an enclosed garage,talk about deafening!!
mhajek18
12-30-2015 03:40 PM
autumnmass
07-02-2015 10:35 PM
gobraves423
06-06-2015 07:03 PM
