How to get more HP?
How to get more HP?
I have a 07 chrysler crossfire coupe manual and I am trying to get more horsepower out of it. I already have a cold air intake, exhaust system, and reprogram my ECU. Is there any other ways I could squeeze more HP out of it? Is it possible to turbo or supercharge this engine or not because I can't find anything for it?
Re: How to get more HP?
I found this on eBay stating that this turbo kit is compatible for chrysler crossfire. would this work?
T3/T4 Hybrid Turbocharger Kit T3 T4 Turbo -3an oil feed, Downpipe, BOV, Stage 1 | eBay
You might wish to install an oil catch can. Believe it or not, they have been known to increase HP by 5-7 well, horsepower.
How? Here's what the folks at Lindsey Racing have to say:
Venting your crank case back into the engine is great for emissions, but not for optimum performance. All serious race cars have separate catch cans for oil vapor. Why?
1) Oil vapor does not burn. When your engine is pumping or inhaling oil vapor, it is displacing a certain percentage of air/fuel mixture. The more blow-by you have, the more air/fuel you're displacing. This means you're not getting 100% air/fuel into the cylinders. Removing the crank case breather from the intake system will eliminate this problem.
2) Oil vapor reduces the octane rating of your fuel. Oil vapor causes problems in a naturally aspirated engine, but is twice as bad on a turbo charged one, where octane rating is critical. If you're running 93 octane pump gas and injecting oil/air vapor into your combustion chamber, along with your fuel, then you no longer have 93 octane fuel. How much is not certain, but it may mean the difference between detonation and no detonation. Better safe then sorry.
3) When you suck all that oil into your turbo, and into your engine, you can clog your cat, coke up the turbo, and even knock the ring lands out of your pistons as it did on the turbo Mustang and Pontiac.
Does this mean that a remote crank case breather can make HP? Does this mean that a remote crank case breather can help keep from blowing a head gasket? The answer to both questions is "YES"!
The amount of oil that enters a cylinder on a car without the CC kit is minute, you only have to see the amount of oil collected in the can when you change the oil. Divide that amount of oil by the number of firing strokes of that engine in that time to realize it. That 5-7 hp that must be on a real loose engine burning oil by the bucket.
The CC kit they are selling is totally different from the one we use, our system is closed and opening it up like theirs would wreck the tune.
Let me hazard a guess here, Lindsey Racing is selling oil catch can kits?
I assume Lindsey Racing does not have regular road use in mind.
on
Post # 30 in this ( https://www.crossfireforum.org/forum...-2-m112-2.html ) thread! If you follow the entire thread you'll find this mod is easy but also super simple. Just make sure you take your time (don't break anything), and when you put it all back together, you line everything up properly (no intake leaks). Have FUN!
you sound like a person that adds hp and then wants more,,,I looked into a mirror and saw the same thing LOL.
the only thing that will ever make you happy ia " put a v8 in it",, and i & Rudy of course can do that for you for less money than you think. take a look at this one. https://www.crossfireforum.org/forum...crossfire.html
on
Forgot to include, it is a reported 10HP with this FREE mod!
Just to give you the way it is in the real world on horsepower for your car.
1. new car bought from dealer ship, say 350 hp, cost of mod per hp is 100lbs of weight off the car. or $100.00 that is for the first 20 hp.
then it changes to 300lbs or $500.00 per hp for the next 20 or so hp
by now your 1/4 mile time has gone from 14.10 to 12.99,
now you don't look at hp any more you look at lowering your ET so now you need to spend $1000.00 to $2000.000 to drop you by a tenth, so cost of the car + your mods and maybe you can run 12.00 or 11.90 .
2. you buy a so called race car ready for the track but want more say like a GTR cost $112,000 ,claimed 480hp runs in the 11's add $100,000.00 and run in the low 9's so that is $2600.00 per tenth. this was a friend of mine and it is facts. he did it because the first time he ran me he lost,,,didn't see him for 6 months , then he shows up at the track and said jim i want to run you again, i ran a 10.74, he ran a 9.32
3. now is the time for a V8 for a lot less money.
USAF 1964 to 1968 jim
also see the GTR's hp here http://www.caranddriver.com/columns/...sepower-column
