daytime running lights
Re: daytime running lights
Originally Posted by Barb
just new to this forum thing. so sorry but i cannot get to that link for some reason??
it just brings up the crossfire forum page? what am i doing incorrectly?
I'll do a search for you though, hang on.
Edit, lots of info, enter 'DRL' in search.
As you have to change the switch you may find a Canadian who wants to swap their switch for your switch.
There is another way to do it though, but it's not the best way.
Hi: I checked into that and its 187.00 but they say because its a Crossfire that the dealer should do it. There are other issues that crop up?? I'm wondering if this is true as the dealer wants like 1.5 hrs of labour at 94/hr and 462 for the switcher. The guy I purchased it from hard wired it which created problems with the airbag. I want this done correctly and so as not to interfer with other programing. Are you sure Canadian Tire will be ok?
I'd take Crappy Tire's advice and get the proper headlamp module, it's the simplest and correct solution. Good luck!
I purchased the canadian switch from a dealer for $432 and replaced it myself. It was a quite tricky getting the dash pieces apart then there were about four wiring harnesses that plugged into the switch.
I think the dealer is your best alternative.
Originally Posted by brian_omeara07
Or another alternative, turn your headlights on before you drive anywhere and spend $400 on a magnaflow or something
well i am as the previous owner hard wired it so it passed. now im dealing with the other issues that the wiring has caused so im wanting to make it right. i was wondering if it was best to go the the dealer and pay the price or crappy tire? also wanted to know the correct way so i know what im talking about.
I would go to the dealer and have them rectify the wiring issues caused by the previous owner. They should be able to find the botched wiring and remove it back to original. Since you are already compliant I would not purchase the switch........unless you are planning on selling the car in the near future because to certify the car for sale you would then need DRL. So, save yourself some money and just get the wiring issue cleaned up by the dealer.
How do you switch from us to canadian programing on an 07?
How do you know that the wiring changes for the lights caused your problems? Is it possible they are caused by some other issue.
How long have you had the car, if it has a warranty of some kind get it fixed on that. If not and I think this may be true, you are in a bind.
Hi Barb,
Any luck on it?
I moved to Canada and also in the process of turning on the DRL for my 05 Crossfire. The dealer just told me it would be enough to reprogram the country code from USA to Canada and it should work but mine did not. He told me he has done for some others and it did work.
After some research with MB and Chrysler he told me it is necessary to replace a kind of fuse box or whatever it is. This is what the computer is saying.
The part costs $600 and with labor it might jump to $1,000 and I think there is no guarantee that this will work.
The re-programming and the diagnostic will already cost me $200. Really do not know what to do.
Wondering if you found a solution for yours. I'd like to have a talk to you if you could PM your phone.
Thanks.
Any luck on it?
Thanks.
on
That would be ideal except if you want to register/plate the car you have to be compliant with Canadian laws = Daytime running lights.
Originally Posted by marcossaito
Hi Barb,
Any luck on it?
Thanks.
Any luck on it?
Thanks.
One simple solution is borrow a Canadian switch for the test and switch it back out later.
