Syfi's DIY DCAI
on
Syfi's DIY DCAI
I've had a few inquiries on how I made my DCAI, so I put together a pdf file that shows all parts used and where I procured them online.
Syfi's DIY DCAI.pdf
Syfi's DIY DCAI.pdf
redsnake (09-04-2023)
on
on
Re: Syfi's DIY DCAI
Thanks Doc. I think I found some useable devil horns. I'll probably trim the flange and see how these will work. Should have them next week. If they end up being too flimsy, I'll try coating with epoxy or may even use them as molds and fab some custom FB ones. The size and shape looks like a good fit.
Allstar Performance ALL42141, Allstar Brake Ducts | Allstar Performance
UPDATE (12/1): Managed to fit the Brake Ducts. Trimmed the flanges completely off for easier fit. Just pushed them into the silicon hose for perfect grip without any need for clamps. One corner just does get behind the frame which holds them solidly in place. Drivers side was a PITA but it fit above the horn bracket without any modding.
Mike S
on
Re: Syfi's DIY DCAI
I'll admit that I used your idea for the inline filters. This is the SRT version. The straighter rammed-air flow into the filters just makes better sense to me. And the SL55 "Y" connector which simply clips onto the throttle body makes the install and removal of the entire setup super easy.
http://www.fabtech-performance.com/#...-intake-system
on
Re: Syfi's DIY DCAI
It has been done before with good success. Nice intake!
Mercedes Benz AMG Performance Parts AMG Performance Packages
on
Re: Syfi's DIY DCAI
Re: Syfi's DIY DCAI
I have almost an identical DIY DCIA. I used the following "T" to connect to the TB.
Black Rubber Intake Tee 3" ID: Intake Hoses, IntakeTubing, and Intake Clamps - Intakehoses.com
I also have a set of devil horns from Needswings, just can't see them in the picture.
TTYL
Ron
TTYL
Ron
