grille mod with pic.
Old May 19, 2008 | 02:01 PM
Default grille mod with pic.
first let me tell you I have had the car 12 days ,,went to the track(drag strip) twice,
day one 76* 8pm run 5 13.40 @10589
8:55 pm run 6 13.40 @10603
it took the first 4 runs to get use to the car,, i am use to a front wheel drive PT Cruiser that runs 12.93 @ 108. any way the next week back to the track with only the grille mod temp 77* run 1,and 2, were before 8 pm and were #1- 13.46 #2- 13.39 now it is 8:23#3- 13.30 @ 106.44 #4 -13.25 @106.63 here is the mod
#2cut the plastic on the inside of the grille on both left and right sides the upper bar onlycrossfireSRT-6grillemod007.jpg
heat it with a mini tourch so you can strighten it by hand until it is level with the rest of the grille barcrossfireSRT-6grillemod009.jpg you can see the opening that now lets air drive right to the intakecrossfireSRT-6grillemod011.jpg see how the opening is so much larger
Old May 19, 2008 | 02:05 PM
Default Re: grille mod with pic.
onced the grille in reinstalled ,,you can't see any differance but it works. crossfireSRT-6grillemod017.jpg
crossfireSRT-6grillemod015.jpgif you have any questions pm me this mod is free no money out of your pocket you can heat the plastic with a lighter or a match (may take longer, also with a set of wire cutters you can cut the plastic ,,just cut small bights as the plastic cut with wire cutters wants to crack jim
Old May 27, 2008 | 02:46 PM
GatorLCA's Avatar
Wonder how well it will work with a Needswings intake...I agree that the openings for the grille are rather small
Old May 29, 2008 | 09:07 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
very nice! im doing this mod today! if anyone has a dremel with the cutting blade that might be easier then wire cutters or tin snips.. just a thought.
Old May 29, 2008 | 06:22 PM
KrzyFast's Avatar
That is an awesome mod! Great idea. Thank you for sharing and adding pics too! Much appreciated.
A dremel is the ticket! I didn't plan on reusing the factory tube inserts next to the radiator when I changed my intake - rather than remove the radiator or parts around the radiator in order to remove the inserts, I used the dremel to "trim" them loose. Worked like a charm. I do have the flex shaft accessory to my dremel, without it, the process might be more difficult.
Just my $.02.
Later,
KrzyFast
Old May 30, 2008 | 02:13 AM
bobo54545's Avatar
When I got back from the track the first time I was all hyped up and wanted to do anything I could to my car to improve it, I actually took off the grille and was looking into just actually cutting off the part you bent but your method is a lot better, I might be performing this mod too, that is as long as it clears the filter on the Needswings intake. Thank you for the little how-to btw I wouldn't have thought you could heat and bend the plastic like that.
Old Jul 30, 2008 | 06:30 PM
finally a mod I can do that doesn't cost me money....thanks man....
Old Jul 30, 2008 | 11:54 PM
Mimi05SRT6's Avatar
Nice easy mod and yes a dremmel is the best way to go about it.
Old Jul 31, 2008 | 03:58 PM
Moparrbust's Avatar
dremmel= second best....................The best way to do it is with a pneumatic pencil grinder(best custom tool ever). I used mine to cut out all of the angled tabs so it has more straight through flow to the intake and also the radiator/condensor.
Old Jul 31, 2008 | 05:36 PM
BlueStorm's Avatar
I don't think you don't want to remove all the angled tabs, because they protect the condenser coils from rocks, bugs and stones at high speeds on the highway. kind of like a shield. just take out the ones that block the air intake
Old Aug 1, 2008 | 04:24 PM
Moparrbust's Avatar
I live in the city and even when driving cross country(in other cars) 5 times I have never had a decent size rock jump up and into my condensor. I have however had several pebbles chip my damn windshield(s).
Old Aug 1, 2008 | 07:24 PM
Just remember-everyone has a rock with their name on it!
Old Aug 11, 2008 | 07:32 PM
Jeep2Xfire's Avatar
Talking Re: grille mod with pic.
I recently did this and I've noticed that the temp dummy gauge usually sits about halfway between middle mark and the next to middle mark. Usually it was pegged on on the middle once warmed up. I cut every fin and noticed a gain in economy as well. Once I get the NW intake, I guess I should do even better??
Justin
Old Aug 12, 2008 | 06:00 AM
Stogey's Avatar
I will be doin this mod soon. I bought a piece of wire mesh from my local Home Depot to secure to the back side of the grille once I cut out the angled louvers. Painted flat black should look fine.
Pics will follow !
Old Aug 12, 2008 | 11:35 AM
Mimi05SRT6's Avatar
Thanks for the tip! I did this mod using a dremmel 2 days ago and it looks great! No one can tell that I did it either! Gotta love the dremmel!
Old Aug 12, 2008 | 05:54 PM
Moparrbust's Avatar
Pics will follow !
You might want to see if you can get the mesh powdercoated. I spraypainted the bare mesh for my SRT-4 and after a few months of bugs, pebbles and whatnot it had a bunch of little silvery specs. Then I just took it off and repainted it every few months(too lazy to have it powdercoated).
Old Aug 12, 2008 | 07:28 PM
My only concern is that a stone or object has a clear shot into the radiator with the grill mod.
Otherwise it seems like a good idea
Old Aug 13, 2008 | 04:03 AM
Stogey's Avatar
I agree Valk ! I have the same fear. The wire mesh behind the grille should do the trick. I tried to find a mesh fine enough to curtail any debris about an 1/8 inch in size and Home Depot had just what I was looking for ! I don't know about powder coating tho, I will just paint the mesh for now. Need to figure out how to attach to back side of the grille.
Old Aug 13, 2008 | 06:32 AM
if you only cut the opening next to the intake opening you want need a mesh behind the grille,, just in case you didn't know the (and most all grilles and bumpers (today)) are made to create preasure behind the grille and in front of the rad, by cutting all the edges of your grille you lose some of that preasure pushing through your rad.,, jim
Old Aug 13, 2008 | 06:50 AM
Stogey's Avatar
Pressure behind the grille ? Huh ? I am not understanding !!! If that's the case what happens when the fan kicks on ? Not being sarcastic here, but I've never heard of this. What's your source of information ?
