Re: grille mod with pic.
That is an awesome mod! Great idea. Thank you for sharing and adding pics too! Much appreciated.
A dremel is the ticket! I didn't plan on reusing the factory tube inserts next to the radiator when I changed my intake - rather than remove the radiator or parts around the radiator in order to remove the inserts, I used the dremel to "trim" them loose. Worked like a charm. I do have the flex shaft accessory to my dremel, without it, the process might be more difficult.
Just my $.02.
Later,
KrzyFast
