grille mod with pic.
Old Aug 13, 2008 | 07:41 AM
mrphotoman's Avatar
Default Re: grille mod with pic.
Originally Posted by Jeep2Xfire
I recently did this and I've noticed that the temp dummy gauge usually sits about halfway between middle mark and the next to middle mark. Usually it was pegged on on the middle once warmed up. I cut every fin and noticed a gain in economy as well. Once I get the NW intake, I guess I should do even better??
Justin
dummy gauge? are you saying it is a fake gauge lol? Also according to your description the temp increased with your grille mod:
so before the mod: halfway mark
after the mod: past the halfway mark
That does not make sense, did you type it "backwards"?
Old Aug 13, 2008 | 08:36 AM
I will see if i can find the test that Mercedes did when they started useing the new wrap around bumpers,
Old Oct 4, 2008 | 09:40 PM
beasticles's Avatar
sex........................
Old Oct 5, 2008 | 02:42 PM
Squirrel Crusher's Avatar
Using a flex shaft dremmel tool with a fibered cut off blade works great. Then a wood working round file for the corners and it will look factory. PS.... Don't follow dump trucks!
Old Oct 5, 2008 | 03:19 PM
I did this some time ago...1 grille for racing, 1 for the road...when the blk grille is on, I'm racing, stock grille for everyday...my temp gauge dropped a needle width with this mod...so it had to help a little...
Old Jan 9, 2009 | 05:56 PM
shreker's Avatar
just did mine!!!!i would think the better the flow the better response!!!
TerryR
Dec 13, 2019 03:27 PM
Apr 28, 2016 02:04 AM
rmcdaniel12
Nov 4, 2015 04:08 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
