Top Stuck Half way up
Old 11-17-2016, 06:21 PM
Jeteka's Avatar
Default Top Stuck Half way up
Need help. I was putting a little window weld in the corner with the top halfway up. Now the button light is blinking and it will not go either way.
Old 11-17-2016, 06:57 PM
Default Re: Top Stuck Half way up
Disconnect the negative battery cable, wait 5 minutes, reconnect and see what you have.
Where in Alabama ?
Old 11-17-2016, 07:24 PM
Jeteka's Avatar
Hey... Thanks just got through doing that. It relieved pressure on the system so I could get the top up all the way. I put towels under the window to hold it up, and left it at that. The light was still on, so I hope it will work right. We'll try it after the adhesive dries. I had stopped with the top door open thinking I could wipe down the gaskets but that was a mistake. I am near Mobile
Old 11-17-2016, 07:36 PM
You can finish locking it in the closed position after the weld sets using :
https://www.crossfireforum.org/forum...operation.html
It should then function normally.
