New Questions on Codes 410 and 335
Everything I've read about the problems with the crankshaft position senson is that heat effects it. After the engine cools down it will restart. After I installed a new crankshaft position sensor the problem came back days later with the same code. One of the replys I got here that the problems with RCM would give a code of PO410. Will the heat also effect the RCM to fail?
davidc90
09-06-2015 10:37 PM
