SRT-6 Spring Trim
on
SRT-6 Spring Trim
Now that I have my SRT on jack stands and the
1) Rotors removed (out for dimpling, slotting and black Zinc plating)
2) Calipers removed for painting
3) Replacing pads with Rotex Gold
4) Installing a set of Goodridge steel braided brake lines (on order)
5) Tire repair (nail)
I thought well go one more step and lower this puppy.
Question - has anyone attempted to trim the stock coil? Can it be done by just compressing the springs and trimming them the appropriate amount or would the springs need to be removed for trimming?
I would not want to remove the springs myself, I will pay to have a set of Eibachs installed if I need to go that route, but would have no problem using a spring compressor and trimming them if I did not have to remove and replace the suspension to do the job and it was possible to begin with.
I know the Eibach springs are softer then the SRT and firmer then the Limited but I have come to like the stock SRT suspension - it's just 2" to 2.5" taller then I would like.
Thanks for the help.
Re: SRT-6 Spring Trim
on
Thanks Steve,
Actually I was thinking about using the hobby-shop on the base. They have lifts, boom jacks, tools, etc.
Next question for someone who has done this; are the top and bottom coil pads keyed for the coil?
What I mean by this, will I have to trim exactly one coil so they will fit into the pad or does orientation of the spring/pad matter?
Thanks - armed with this info I may give it a shot on my own.
Thanks Steve,
2005 Ragtop
10-03-2015 03:01 PM
BlackJax-SRT
09-18-2015 07:03 PM
55chevy
09-13-2015 07:38 PM
