which springs to go with?
Re: which springs to go with?
get the eibach. h&r may lower the car a little too much for you.
you may also need to trim the control arm thinger majig bolt since it may rub the inside of your tire.
you WILL get tire rub. even on stock rims I will get a little bit of rub when reversing hard to the left/right or over some extremely bumpy terrain. there are special 'rub spots' in the wheel wells and it does not cause damage.
2005 Ragtop
10-03-2015 03:01 PM
Mikerdougie
08-26-2015 11:28 PM
wannaGOFAST
South Forum
08-14-2015 01:20 AM
