Tirefit expiration
Old 07-19-2008, 09:28 PM
Chairmann's Avatar
Default Tirefit expiration
Hello. Can anyone tell me if I can still use the can of tirefit sealant beyond the expiration date? I have a can the appers to have expired (05/07) Thanks in advance.
Old 07-19-2008, 10:18 PM
FTroopChief's Avatar
Default Re: Tirefit expiration
Welcome aboard. My opinion is that it's like a can of beer, "best if used by xx-xx-xxxx". Prob be ok 'till you need it. A manufacturer's CYA statement.
Spring a ten spot and buy a new can. Also a T handle tire repair plugger kit to get you where you are going. If your mini compressor was misappropriated as was mine, you can get one at AutoZone for under $20.
John P
Old 07-20-2008, 10:03 AM
Administrator / Senior Member
Don't use the fix-a-flat stuff at all.
New or old it will destroy your tps and most likely even your tire.
Just a plug kit and a pair of needle nose pliers should get ya back on the road in most cases.
RacerXofFL
09-15-2015 05:00 PM
FTroopChief
08-30-2008 02:17 PM
DamnRock
05-17-2007 05:27 PM
thegoalie
10-11-2006 04:34 AM
XFire-Amore
06-23-2004 09:20 AM
Quick Reply: Tirefit expiration
