Spacers 4 XF on E-BAY
Old 09-12-2008, 06:34 AM
iduesoli's Avatar
Default Spacers 4 XF on E-BAY
What do you think guys????
http://cgi.ebay.com/ebaymotors/PAIR-...mZ370085306760
Old 09-12-2008, 07:14 AM
NoCones's Avatar
Default Re: Spacers 4 XF on E-BAY
at that width, much better to get some with the proper hub size...and with a hubcentering lip
Old 09-13-2008, 08:06 AM
Fritzauf's Avatar
Those will make your car shake, rattle and roll for sure and you won't like that.
If you install spacers, better get hubcentrics. They snap into the wheel and hub properly centered so they won't cause vibration or banance problems.
With spacers you will also need to install longer lug bolts.
Old 09-13-2008, 08:52 AM
CALL911's Avatar
[quote=Fritzauf]Those will make your car shake, rattle and roll for sure and you won't like that.
If you install spacers, better get hubcentrics. They snap into the wheel and hub properly centered so they won't cause vibration or balance problems.
I have to disagree with you. If they are well made, and they do look the part, and are true, you should not have any vibration or balance problems. reason being, the spacers are very close to the center of the hub. Vibration probs would only be noticeable if they were farther out on the wheel, causing centrifical force to throw the wheel out of balance.
Old 09-14-2008, 06:15 AM
Even though it may cost you more now, buy hubcentric spacers. It will save you money and the headache in the long run.
Old 09-14-2008, 05:50 PM
Fritzauf's Avatar
Don't screw around with those swiss cheese spacers. Here's some GOOD advice.
http://www.optionimports.com/wheel-s...-e-class-.html
$71.10 / set
You're welcome.
Old 09-14-2008, 06:57 PM
Moparrbust's Avatar
I bought my pair of new hubcentric 15mm spacers with 5x112 bolt pattern(no extra holes for multi makes)from a company on ebay for $60 shipped.
Old 09-15-2008, 04:21 AM
iduesoli's Avatar
Thanks a lot, guys! I am checking now Eibach and H&R spacers; Eibach makes only 10mm and 15mm (only for rear axle); H&R makes a lot more sizes but I am having problems to understand the thickness of the spacers. Thanks again.
maxcichon
05-14-2019 07:30 PM
grip grip
31
09-27-2015 10:06 PM
09-26-2015 10:21 PM
Valk
09-17-2015 11:43 AM
04Fire
09-15-2015 07:40 PM
Quick Reply: Spacers 4 XF on E-BAY
