Old Aug 26, 2025 | 09:30 PM
M60A3Driver
Default Re: Magnetic clutch of the AC compressor
Originally Posted by CaptArt
I recognize this is an old thread; but, I appear to have the same issue. Did you ever run the test? What were the results? I don't suspect a leak in my system, as it was working fine until the alternator failed. Upon replacing the alternator everything worked except for the air conditioning. I'm trying to determine if the is a cause/effect of disconnecting the battery to accomplish the alternator change. Thanks.
Did you disconnect the negative battery cable first?
When reconnecting the battery, did you connect the positive first?
If you didn't do it in that order you may have caused an electrical spike. I would suggest checking your fuses first.
