Old Aug 27, 2025 | 03:19 PM
  #163 (permalink)
6speedM113's Avatar
6speedM113
Default Re: M113K Into a Crossfire - Journal
I'm learning that this isn't such a bad swap. i also learned that I can use the existing flywheel and use a SLK350 clutch for the amount of torque since I'm no planning on tunning it up.
here's the end result; make the 55AMG running stand alone on the CLK (enter josh from the mercedes swap shop, idealy keep the obd 2 for blue tooth readings temps/rpm/speed/pressure/fuel. mate the engine to the crossfire, strip it down to the bare minimum to be able to operate, at that point, it wil be chassis swapped.
i don't want t clog up this thread, so I'll continue on mine
thank you
rex
