Re: 2004 Crossfire just bought for cheap.
"Everything"just went south on this great deal! Took it for a second drive and found some faults with the 6-speed transmission. The shifter is "loosy goosy" and had to try several times to go into reverse. Hard to shift thru the gears and not snapping into the proper shifted gear. Not grinding just missing gear changes. I'm "guessing" worn syncro problems. Don't know all the in and outs of these trany's. After dong some research on used tranny's i my as well turn this into a parts car! I'm "stupid enough" to try a rebuild but that's looking at $1500.00 plus "if" I was able to do it myself. At the tranny's rear is a tail shaft assembly with shifting linkages. Don't know how much a worn out shifter could create. Transmissions just aren't in my simple brains knowledge base. Anyone have any suggestion for me? Thanks
PICTURE IS FROM WHEN THE FORMER OWNER'S MECHANIC SWAPPED OUT THE ENGINE.
