Old Aug 28, 2025 | 02:58 PM
Romad's Avatar
Romad
Default Re: 2004 Crossfire just bought for cheap.
Things i've repaired in the last two days:
1. Installed new seat relay. Right seat ok but driver side won't go forwad or backward.
2. Replaced license plate light fixtures with led fixture.
3. Replaced both air filters.
4. Straightened front grill of bends.
5. Aligned hood latch.
6. Serviced fluid levels and aired up all four tires.
Things still need resolving:
1. Install another used air pump in the trunk. Don't really mind just using the key.
2. Discover which is bad in tranny, syncros or shifter adjustment.
3. Brakes good but should be checked. Had break job about a uyear ago.
4. Find out why moisture is in the drivers side head light. (ventilation??)
5. Check under side for rattling exhaust and squeaky left rear suspension.
6. Replace drivers side wiper arm where i broke it off when closing ho0d.
7. Paint all four rims and centers. Someone had painted them grey over the years.
8. Replace fob key case.
9. Bleed the clutch fluid. Grabs all of a sudden.
what else could possibly go wrong with a 22 yer old car! That being said this car really runs well!
