Old Aug 30, 2025 | 09:03 PM
  #41 (permalink)
Romad's Avatar
Romad
Default Re: 2004 Crossfire just bought for cheap.
2004 Crossfire 6-Speed manual shift
Completed Items:
1. Installed new seat relay. Right seat ok but driver side won't go forward or backward.
2. Replaced license plate light fixtures with led fixture.
3. Replaced both air filters.
4. Straightened front grill of bends.
5. Aligned hood latch.
6. Serviced fluid levels and aired up all four tires.
7. Installed another used air pump in the trunk. Door locks now work.
8. Removed broken security module. Battery not discharging now.
9. Put new FOB case on key.
10. Replaced hatch struts
11. Moisture was in the drivers side head light. Ventilated light assembly.
12. Bled clutch and added new brake fluid.
To Be Done:
1. Fiberglass rusted trunk floor.
2. Discover which is bad, tranny syncros or shifter adjustment, replacement.
3. Brakes good but should be checked.
5. Check under side for squeaky left rear suspension.
6. Install new shifter assembly
6. Install new cabin filter.
7. Replace driver's wiper arm. 8/312/25: ordered new wiper arm
8. Make a new speaker grill for L/door
9. Repair rear hatch lock
