Old Sep 1, 2025 | 08:56 PM
M60A3Driver
Default re: Top will not operate
Originally Posted by MGS53447738
2006 Crossfire Limited Convertible.
Top will not operate , when unlatched will only constantly beep and will not move!
lowered manually and tried to raise same beep no movement!
checked limit over passenger seat and divider switch in trunk and both seem to be working!
No leaks on hydraulic cylinders and reservoir full!
Guess need someone reasonably close in miles to North East Tennessee to scan and locate problem?
Hi,
a couple of other things you might check are any blown fuses, and the voltage of your battery. When you unlatch the top,do the windows go down automatically?
You might also want to check out this thread. The posts by pizzaguy in the thread should be helpful.
LINK - Top won't go down
