Top will not operate
Old Sep 1, 2025 | 01:07 PM
MGS53447738's Avatar
Default Top will not operate
2006 Crossfire Limited Convertible.
Top will not operate , when unlatched will only constantly beep and will not move!
lowered manually and tried to raise same beep no movement!
checked limit over passenger seat and divider switch in trunk and both seem to be working!
No leaks on hydraulic cylinders and reservoir full!
Guess need someone reasonably close in miles to North East Tennessee to scan and locate problem?
Old Sep 1, 2025 | 08:56 PM
Default re: Top will not operate
Hi,
a couple of other things you might check are any blown fuses, and the voltage of your battery. When you unlatch the top,do the windows go down automatically?
You might also want to check out this thread. The posts by pizzaguy in the thread should be helpful.
LINK - Top won't go down
Old Sep 2, 2025 | 10:55 AM
dcskmail's Avatar
Watch all the videos on youtube by Top Hydraulics to help with you problem The website will not allow me to post it type : Crossfire top hydraulics in the youtube search field then scroll down to find all the videos
Old Sep 2, 2025 | 11:34 AM
edmoncwheeler's Avatar
I had this problem and discovered that if you do not properly latch the divider in the trunk, the top will not operated, just beeps
jeromecurrier
May 13, 2024 10:23 AM
avgfan
Jul 24, 2023 11:43 AM
lifecaster
Apr 6, 2020 01:39 PM
gwp3235@gmail.com
Oct 9, 2017 11:19 AM
crossfirefun
Mar 30, 2008 03:29 PM
