Kountryking23
thank you so much this things kind of a pain but enjoy tinkering and she needs alot of it . I'm still having issues with everything else oh God so my brights do not work the dams work just fine and my fog lights when I click them they're just like nothing is there and then I have this alarm going off every time I drive il it sounds like its under the driver's dash its the same one that beeps when you leave the keys on or lights on .I did try to pull fuse #9 it's still going off I'm starting to get a nervous tick she's my daily driver so if I could get help with that or what should I go at next the forums are kind of a lot and as I'll need to know to do this myself cuz I'm learning this is an expensive car and I'm definitely I need to save money guy so I got to figure it out myself by doing it I appreciate you guys so much thank you for those who've already helped me
Regarding the high beams, the multifunction switch sends a signal to the ICM (illumination control module). Make sure the multifunction switch is turning on the high beam function. Section 8R-35 All that can be found in the tech manual and can be downloaded here:
https://www.crossfireforum.org/forum...ollection.html
As for beeping under the dash, have you tried plugging in the passenger seat? If could be the seat sensor is triggered even tho' nobody is there.
