Kountryking23
I got the seats figured out thanks to one of yall i just needed to solder the relay under the dash I would have never thought of that
okay for the alarm system I don't know if it's actually the alarm I think it's whatever the beeping is when you leave your keys in the ignition that constant flow beep kind of high-pitched and it's from the top left corner of my Dash I can't see anything when I look under there but it will go off when I hit like 3 miles an hour roughly be continually until I come to a complete stop it does not beep when I go in reverse I did pull my center console and my everything that goes with it the heater ***** and assembly unit the all the buttons the one thing that I did that made me think it might be the real sensor is or something over there I jacked the car up to check my brakes spun the tire realized that they are sticking a little bit dropped it down fired it up and went to go get to the store to get brake cleaner and I noticed the beeping I've checked all my doors they were shut I'm not 100% sure on how to test if the switch is a bad somebody had mentioned that I appreciate your guys's patience and working with me as I know a bit about cars anything pre-computerized which is simple fuel spark air however these newer cars I never wanted to learn until a couple years ago kind of like the computers so I'd like to figure out the Forum I go familiarize myself with it man but I'm kind of learning both things on the Fly here thank you for your time guys you're awesome
