Old Oct 20, 2025 | 08:57 AM
pizzaguy
Default Re: 2004 Door Locks "Automatically"
Originally Posted by Romad
When i program the locks to stay unlocked it does not last. Hours later or even the next day it's right bck to auto locking! Must be a glitch in my ecu or screem i'd guess.
The ECU plays no role in door locking. The SKREEM only commands a door lock/unlock event when the FOB lock or unlock is pressed or when you use the key to turn the lock cylinder in the driver's door.
The autolock is a function that either exists in the CLP/SSM, or between the BCM and the CLP/SSM. I suspect it's all in the CLP/SSM but without monitoring the CAN BUS between the BCM and CLP/SSM, I cant say for sure.
One clue is that the console button is wired directly to the BCM. (SKREEM commands are also passed directly to the BCM - the BCM tells the CLP/SSM what to do over the CAN BUS that connects the BCM to the CLP/SSM.
