Old Oct 22, 2025 | 02:25 PM
  #388 (permalink)
nemiro's Avatar
nemiro
Default Re: Worlds Cheapest V8 Swap
Originally Posted by 6speedM113
so is the name of the company that sells these is pro one performance? Has anyone tried these? Are they direct bolt on?
I have a set of these for someone else's project. On the outside, they look decent, Interior needs a lot of grinding, as no effort was made in construction to make them actually flow, or fit the pipes up. I am going to test fit them before cleaning them up.
did you have to do any persuading to the down pipe connection or do they just line but design?
This method is know to work perfectly, but it takes time and patience to cut, fit and weld. Also, must use SS MIG wire, with matching gas to get rust proof welds. I need to go back and look, but think I used 308L and argon.
