Old Oct 26, 2025 | 07:40 AM
Romad's Avatar
Romad
Default Re: 2004 Drive shaft removal. Help!
The bearing on the right is what's being sold for all Crossfires but stipulates for A/T tranny's. The one on the left is the "only one" I found that stipulates for std transmissions for $23. It is the correct bearing for std shift transmissions even though the other "might" work as well but is much more robust and stiffer in construction.
I have such a mix and match, "and some missing," of metric wrenches that I treated myself to a new set of 12pt box end combo wrenches on Amazoo for $29. Should make life a little easier than the mess you see in the pan.
