Old Oct 28, 2025 | 05:01 PM
KENNESSY's Avatar
KENNESSY
Default Fuel pump has power but doesn’t work?
So we got a 05 convertible and it’s has some issues. The one I’m currently stuck on and can’t figure out is the fuel pump not working. The car was parked for roughly 8-12m on the back burner and at the time the fuel pump worked but a hose had a leak so when I would crank it, the pump would spray gas everywhere from the hole. So here recently I’ve decided to go in and buy new parts and fix everything but in the time it sat the fuel pump stopped working. I bought a brand new pump and went to put it on and it still doesn’t work. I’ve tested the pump directly on a battery and it works as it should and I’ve tested the cables that connect to the pump for 12v and we’re good there, just when I hook it up, it doesn’t work. I’ve tested fuses and relays as well and I’m stumped. Am I missing something? Please help! Thank you in advance!
