Old Nov 2, 2025 | 07:33 PM
zip439's Avatar
zip439
Default Re: Engine enhancer in a bottle! (2006 CF)
See my post above. The adjusters are "similarly designed" so yes they work much like a lifter.
Next time you are nearing an oil change put a quart of Dexron ATF in the oil and run it the last couple hundred miles with the ATF in the oil. Then change the oil as you normally would. It may just work and it won't hurt anything.
