Engine enhancer in a bottle! (2006 CF)
Old Nov 2, 2025 | 05:21 PM
zip439's Avatar
Default Re: Engine enhancer in a bottle! (2006 CF)
Give it a try.
Our engines do not have push rods and lifters, but the valve adjusters are similarly designed.
There is a sticky in the TSB and How-to Articles on how to change the adjusters.
Old Nov 2, 2025 | 05:24 PM
Romad's Avatar
Originally Posted by zip439
Give it a try.
Found it. Think I'll just let that adjuster tap! It's not that bad and from what I'm reading it's a major dive into the valve train and timing chain loosening etc. Thank you for clueing me in overhead cams maintenance.
Maybe I'll just add a lot of really fine sawdust into the oil. That should quiet it down! LoL
HOW COULD I NOT REMEMBER THAT THE ENGINE IS AN OVERHEAD CAM ENGINE!!!! I'VE ONLY OWNED MY FIRST XFIRE SINCE 2021.
Old Nov 2, 2025 | 07:33 PM
zip439's Avatar
See my post above. The adjusters are "similarly designed" so yes they work much like a lifter.
Next time you are nearing an oil change put a quart of Dexron ATF in the oil and run it the last couple hundred miles with the ATF in the oil. Then change the oil as you normally would. It may just work and it won't hurt anything.
Old Nov 2, 2025 | 07:57 PM
Romad's Avatar
see my post above. The adjusters are "similarly designed" so yes they work much like a lifter.
Next time you are nearing an oil change put a quart of dexron atf in the oil and run it the last couple hundred miles with the atf in the oil. Then change the oil as you normally would. It may just work and it won't hurt anything.
well i already changed my oil a couple days ago. Watching the video "they" say add 20% of mmo and run. It until the next oil change which would be 7k for me. It is thinner than my 5w-40 but should not do any harm. One quart of dexron atf should be used in the same manner i'm guessing. Both are supposed to clean up the valve train and other engine deposits. What ya think?
BlazingSaddle
Sep 29, 2021 11:19 AM
former NXMX5
16
Jul 16, 2021 09:48 PM
alexdc
Jan 24, 2018 11:18 PM
70GT6
Jun 29, 2010 12:14 PM
Fritz123
Jul 23, 2008 07:19 PM
