Old Nov 2, 2025 | 07:57 PM
Romad's Avatar
Romad
Default Re: Engine enhancer in a bottle! (2006 CF)
Originally Posted by zip439
see my post above. The adjusters are "similarly designed" so yes they work much like a lifter.
Next time you are nearing an oil change put a quart of dexron atf in the oil and run it the last couple hundred miles with the atf in the oil. Then change the oil as you normally would. It may just work and it won't hurt anything.
well i already changed my oil a couple days ago. Watching the video "they" say add 20% of mmo and run. It until the next oil change which would be 7k for me. It is thinner than my 5w-40 but should not do any harm. One quart of dexron atf should be used in the same manner i'm guessing. Both are supposed to clean up the valve train and other engine deposits. What ya think?
