Old Nov 4, 2025 | 10:12 PM
Romad's Avatar
Romad
Default Re: 2003 made in Germany vs. 2004 made in the us?
Originally Posted by CrossBlonde82
So I'm in desperate need of a center bearing and support, parts place sent garage wrong part so I've been tasked to find one, everything online says 2004 to 2008 but I'm assuming from everything I read on here that it will be the same part 01234581M if anyone could confirm you'd be doing me a favour, I just can't afford the time or money getting more wrong parts.. MOT looming lol
I just replaced my center support bering and as you I was confused about the two different bearings being sold. I ordered both and returned the one that wasn't just like the bad one. "Appears to me" that either will work for automatics or manual shifts. I found one that advertised for standard tranny, $23, and used it and returned the one that advertised to fit all Crossfires. However the A/T was more robustly built. "Only" took me four days to get it changed and put back in car. LoL. My U-joint splines were rusted solid into the front part of the driveshaft and eventually had to pay to have it separated. Don't forget to grease the splines and check both the flex discs for excessive wear.
