CrossBlonde82
Thanks, the garage is doing my repair, he's already done the rest of the work, checked everything else but was sent the wrong part 🫣 when I search only one comes up that will fit the automatic and says all crossfire 04 to 08, doesn't seem to be any other option so I hope it's the right one 🤞🙄
Here is the correct part. I used this when I replaced mine. I have a manual transmission in my Crossfire:
https://needswings.com/driveshaft-support-and-bearing
I hope your mechanic is also replacing both of the rubber flex discs as well.
Here's a post I did when I replaced my driveshaft bearing and flex discs:
Driveshaft support bearing & flex discs replacement
