Old Nov 8, 2025 | 07:13 PM
  #120 (permalink)
Romad's Avatar
Romad
Default Re: 2004 Crossfire just bought for cheap.
Is it really "ever" done? I think I'm getting close to getting everything fixed. Here's an updated list of things I know that are still needing to be done. The "things to do" list is getting pretty short from other list! I did paint my rim center caps black today and look good. Now need to find some sort of 2" medallion to glue to the center.
1. Fix hole in trunk 2. Fix the hatch back lock 3. Install hood pins 4. Install new fender inserts 5. Oil change just in case 6. Fix loose mirror 7. Bleed brakes & clutch with Dot 4
Who knows what kind of tool needed to tighten the interior mirror? I can't twist my neck and head to see inside the two holes of the mirror. Don't really want to replace it but rather just tighten it up so it's not floppy! I added an "over mirror" with dash cam on the OEM mirror.
