Old Nov 10, 2025 | 10:46 AM
xintersecty's Avatar
xintersecty
Default Re: Temporary Rough Idle during Warm-Up
Originally Posted by stlouistrucker
Thank you zip439. Since I'm not getting any fault codes is there a way to check the EGR valve for sticking open? FCP Euro has the genuine Mercedes for $188.99. I don't want to start throwing parts hoping that is the problem.
Here is my solution I found with my EVAP valve. I plugged the vacuum line from the intake to the EVAP valve. Which led me down a issue with gas in the charcoal canister. Fuel in Charcoal Canister
Plug it up
Plug it up
This will give you the idea that the problem is upstream of the EVAP valve.
