Old Nov 10, 2025 | 10:50 AM
richb55's Avatar
richb55
Default Re: Dead throttle pedal
Originally Posted by OTW
Hello to all. I've been lurking on the site since October 2022 when I purchased my 2006 aero blue limited 6-speed with 132k miles. It now has 139k miles and any problems I've had have been solved by using the Google/Crossfire method and reading members posts, almost on a daily basis. Haven't found an answer to this one though. The car is kept in dry storage and I bring it out on average every other week, to tool around town or short trips. The other day I went out and started it as usual. Cranked right up, idled at normal rpm, ran smooth with no miss or stutter. Put it in gear and when I gave it some gas, there was no change in rpm. Pedal goes straight to the floor with no changes to the engine speed. Was able to pull it out into the daylight with only idle speed. Checked all the fuses, swapped out the spare RCM, still no gas pedal. Today I took out the MAFS as a starting point and went to all the local parts stores looking for a Bosch replacement. No Bosch was found. I'm guessing Rob will have one unless somebody steers me to another supplier. My thought on starting there, I wasn't sure if the Throttle Response Sensor is tied into that or not. Please advise. I'm hoping someone else has had this problem and has a definitive answer on what to replace. I really don't want to make make more than one trip under the dash to replace the Pedal Response Sensor. My old body is still able, buy not as willing as it was three years ago.
Small tech tip-The MAFS is held on to the main body by two no-tamper screws. I used two small watchmakers flat screwdrivers in the star portion of the screw head and then used a small cresent wrench to turn them. After a good full turn, I used plyers on the screw head the rest of the way. You almost need three hands to maneuver the combination but patience will get you there. Before I put the screws back in I will grind a slot in the head with my Dremel.
Thanks,
Terry W
search reset throttle position or. Throttle reset. It’s a key on / key off procedure. Worked on my coupe
