Old Nov 21, 2025 | 04:22 PM
Valk
Default Re: High Oil Temperature
Originally Posted by Ptlmnulty
In the Trip panel. It displayed the oil can icon and the word "High".
That indicates you have to much oil in the engine
The maximum amount is 8.5 quarts and often even 8.5 is a bit to much.
Most of us only put 8 quarts in when changing the oil as the pan always has a small amount of oil after it is drained or vacuumed out
Drain out about a quart and you should be good
Check again when the oil is completely settled and add a bit more if needed
