Thread: Rear tire size
Old Jan 19, 2026 | 10:49 PM
M60A3Driver
Default Re: Rear tire size
Originally Posted by amx1397
I have posted this 3 to 4 times
--------------------------------------------------REAR___________________________________
255/35-19 are 10" wide rim to ground is 3.5" and the tire is 26" in diameter does not rub
265/35-19 are 10.4 wide rim to ground 3.7" and the tire is 26.3 tall ,, does not rub
275/35-19 are 10.8 wide -------------------3.8" -------------------26.6 tall does not rub
285/35-19 -----11,2 wide -------------------3.9 ----------------------26.9" tall and does rub on some crossfires if your suspension is worn.
now You can also run 20" rims the factory suggest a
255/30-20------10" wide --------------------3.0 to the ground-----26" tall
265/30-20-------10.4 wide--------------------3.1-----------------------26.3 tall
any tire over 27" or taller will rub and will not work.
-----------------------------------FRONT--------------------------------------------
225/40-18---------8.9 wide-------------------3.5 ----------------------25.1
225/3519---------8.9 --------------------------3.1------------------------25.2
225/30-20--------8.9----------------------------2.7 to the ground-----25.3 -----all
Note if You want to run 18 all around REAR 265/40-18 ----FRONT stock tire with stock rim or stock tire with 18x8.5 rim
jim
Great information Jim!
Thank you
