Old Feb 18, 2026 | 06:17 AM
fired's Avatar
fired
Default Re: Seat power switches RHD
Thanks M60A3Driver for your advice.
Just to clarify - if all seat functions work except for the intermittent slide back issue... Would that mean that the Relay is not the problem.
To use contact cleaner on the switch -- where are the contacts / access, Doesn"t look like spraying where the slide switch is would get anywhere
Would the seat then need to be removed and somehow open the control box??
cheers
