Old Feb 25, 2026 | 08:17 AM
bossman4's Avatar
bossman4
Default Re: Another Convertible top problem analysis
I am hung up on what to do to clear up the trunk fault. I thought I disconnected the sensor on the latch (making an open connection) that should have cleared up the "trunk not closed" fault, but I got no response from the DRBIII emulator.
Based on the other DRBIII emulator readings, they seem to change in real time, so I assumed the value would flip when I changed it.
I bought a mercury tilt switch to use for the "trunk closed" problem, but I have not verified that a functioning switch will clear the problem....
There is a "weekend crossfire mechanic" in Sarasota that may have experience and somebody closer to Tampa that works on convertible tops.
