Old Mar 9, 2026 | 01:04 AM
M60A3Driver
Default Re: Hesitation from dead stop
Originally Posted by incredible
Actually it's been a few years since I have changed them. I pulled both out and they look like brand new. I opened the pleats just in case and it was actually a disappointment they looked like they had just been purchased. Everything, even the rubber seal was soft, pliable and clean. I wonder if 21 years and the florida heat taken it's toll on sensors.
It might be a faulty MAF sensor or it could be a vacuum leak.
I would check for a vacuum leak first. Inspect all of the hoses and lines going to the MAF and the intake.
There is a small vacuum line on the back of the intake that may be broken or brittle.
A quick way to check for a leak is to have the car running and spray a little starter fluid or carburetor cleaner around the hoses and the intake. If the engine revs up a little, your leak is in that area.
There are some videos on you tube on how to check for leaks.
Good luck!
