Re: Parasitic Draw 2005 Crossfire SRT6
Okay so.....I learned i wasnt leaving the multimeter on long enough. I just hit it and it goes to .6 amps. Well it does this every time when you first hit the post. If you hold it on It slowly went down to .18 amps. I removed the radio and security fuses and got it down to .07. Wasn't holding it on the terminal long enough to get past the initial surge of juice.
I did just get the security alarm removed. It looked brand new though. Checked amps and was still at about .18. Took radio fuse out and stayed about .18 or .17. Took security fuse out and it went down to .07. The alarm is removed so not sure what else would be drawing that extra current from the security fuse. It controls trunk light, which we removed the bulb already. Roof lights which are all off, and the horn as well so not sure what the issue is. Frustrating....
