Old Apr 8, 2026 | 12:25 PM
bossman4's Avatar
bossman4
Default Re: Another Convertible top problem analysis
I have done some more work and analysis.
I disconnected the latch retainer switch from the Power Top Control Module and the DRB III emulator was still showing that the trunk was open. Based on the service manual and wonderful discussions on this forum, Pin 16 on the PTCM is still grounded. Since the latch retainer switch is removed from the circuit, that leads me to believe that the wiring going to Pin 16 on the PTCM is grounded by a short to ground in the wiring between the latch retainer switch and the PTCM connector.
I have separated the wiring loom (PTCM Pin 16) into two sections.
The first section of the loom runs from the latch retainer switch connection in the trunk lid to a connector on the passenger side rear quarter panel. I tested the grounding on the Pin 16 wire and it shows that it is not grounded in this loop. The second section of the loom runs from the passenger side rear quarter panel to the connector on the PTCM. That loom follows a circuitous route from the passenger side rear quarter panel through the back passenger wall. I am assuming it routes from the passenger side to the driver side inside the cabin wall under the carpet back wall. This loom then reappears (from the trunk view) to the driver,s side rear quarter panel where it then connects to the PTCM.
  • I am either going to cut and by bypass that part of the Pin 16 wiring loom by cutting at the pin16 connection at the PTCM and putting a jumper wire to the connector on the passenger side rear quarter panel that connects the latch retainer switch. Once I find out that Trunk Open Signal is fixed, I will need to make the jumper permanent or do the circuitous loom inspection and repair or......
  • Tear off the back panel carpet and speaker panels (again) to see if there is some ground shorting of the green white pin 16 wire along its circuitous route. I had replaced the back woofers and installed tweeters on the back panel after I bought the car and there may be a slim chance that the pin 6 wire got pinched along the route and got grounded. I just want to verify the wiring loom pathway before I am looking for the grounding short on that loom.
So......
  1. Am I correct in my belief that it is a ground issue in the loom?
  2. Am I guessing correctly on the wire loom routing?
  3. Which of the two options (or another) would you pick? I am getting wary of parts being scattered about during the debugging and getting everything back together (again)
  4. Any recommendation on a process for finding the grounding short?
Thanks in advance!
