Old Apr 11, 2026 | 12:03 AM
GraphiteGhost
Default Re: '04 Coupe Automatic for $1.00
Originally Posted by mistykup
Hi Friends!
So far so good with the restoration. She's driving fine, with the exception of the minor rumble from the transmission once in a while (we did the flush a couple weeks ago and I've only taken her around the block a few times). As the warmer weather in New England is fluctuating, I've noticed the rear window has been fogging up from the inside consistently. All the internal panels are still out, as we plan to hose her down pretty well to get any remaining mouse evidence out of the nooks and crannies. I thought maybe the dampness inside is from everything (but the seats) being out, but I think it might be something else.
Are there drains in the hatch I should check for or can the gasket be replaced? Perhaps issues with the seal around the wing? Just spit balling.
Thanks in advance!
There is two rubber plugs either side of the hatch bottom towards the front of said wells, under the foam (if foam piece is still there). Many members poked a hole or cut a big piece out of each to drain if it leaks into there. Good luck with your project!
