Old Apr 20, 2026 | 09:31 AM
  #358 (permalink)
M60A3Driver
Default Re: My Journey with my 2006 Roadster "Svengoolie"
Water pump, Thermostat, Coolant temperature sensor, Hose Replacement and Coolant flush. PART 1 of 7 (10 picture restriction per post) March 29 - April 6, 2026. (working on other things as well).
Svengoolie flushed like he ate too many burritos at Taco Bell!
I'm going to be doing a 1,000 mile trip out to the Crossfires in Athens event in Ohio at the end of May. Although the coolant tested fine with a hydrometer and the pump seemed okay, I have decided to upgrade the 20 year old cooling system.
I am replacing the water pump, thermostat, Coolant temperature sensor, upper and lower hoses and doing a coolant clean and flush.
Special thanks to Rob at Needswings.com for the fast shipping of my order!
This is how I do the work on my car. I'm not a professional mechanic. The pictures and descriptions are for reference only. Any work that you do on your car is your responsibility. Safety first and patience make for a job well done!
