winter storing
Oct 24, 2006 | 12:17 PM
permalink
Idaho
May 2004
465
Re: winter storing
The purpose of jacking the car up is to take the load off of the suspension, but you should put a vapor barrier between the tires and the ground so they don't draw moisture. When I store my car:
Fill the tank and use fuel stabilizer which I run through the injectors before it goes into storage.
Change the oil and filter.
I use a 1" perforated rubber mat under each tire, lift the car off its suspension but not so high as to have the suspension hanging.
Install a battery charger with a floating ground.
Touch up any scratches and give it a good wax.
Cover it with my car cover until spring.
Idaho
View Public Profile
Find all posts by Idaho
