Old Apr 24, 2026 | 08:17 PM
M60A3Driver
Default Re: Blinking gas light?
Originally Posted by 4drturbo
More details on the small rubber hose that the small hard plastic pipe from the evap wastegate??? No idea what that is or where that's at. I'm having the same issue with mine.
I had this issue. It turned out to be a bad gas cap. Here's a good piece of advice; If you do buy a new gas cap, don't cheap out. I replaced my original gas cap because the tether was broken.
I bought a $15.00 one from amazon and after I put gas in my car the gas light started blinking. I disconnected the battery and it stopped for a day, then it started blinking and the check engine light came on.
I had the codes for large evap leak and small evap leak.
Then I bought the correct cap for $33.00, for an SLK 320 and it's been fine ever since.
I don't know if this is your problem or not, I'm just saying what mine was.
