Old Nov 16, 2006 | 03:52 AM
HDDP's Avatar
HDDP
Default Re: MMZ / HDDP Buttonwillow Update !
Yes the clock is wrong... Anyway... It looks like you did a great job for your first time on the track... I only had the chance to observe from the pit lanes while you were flying by... The thing that I find amusing with your video is that your tires squeal... That doesn't happen on racing slicks... No squeal, so therefore you never know when they are ready to break loose until it's too late and you start sliding across the track... Surprise !!!
PS: I think I have the ECU ESP thing worked out... Stewart from SDS racing is going to take my ECU and try to do the mods to turn off the traction control and tune the car for full race spec. I'll keep you posted. Also, the owner of Metric Motors has given me an AMG long block to see if I can build it into my car with the current electronics... If it works, I have to purchase it for $8,000 (GULP)... He gave me the specs. and it turns out that your car has light weight pistons, different cams, larger oil pump, etc... He believes I can replace the engine internals with the AMG version of the engine and still keep it naturally aspirated with slight tweaks to the computer, so I could stay in TTD class without the tech inspectors knowing that I have a different (higher HP) engine...
