Old Mar 27, 2004 | 09:45 AM
Jamikest's Avatar
Jamikest
Default
uhh antenna?
The only difference in the caps, is TPM caps have a seal inside to prevent moisture contamination. If you inspect newer DC vehicles, they have switched to a plastic cap. The new plastic caps are silver to differentiate them from normal caps. Again the difference being the seal inside the cap. Check it out, pull a cap- inside is a small seal.
