Old Nov 25, 2006 | 02:47 AM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: Supercharger kit for The Limited XF
Keep in mind if you put a factory SRT6 blower and intercooler system on a Base or Limited model you will most likely blow the engine as the lower (short block) can't handle the extra pressure.
Unless you build some kind of limiter or use a much larger pulley on the super charger.
Good luck.
